So if you have been paying attention to my build thread then you would know I just put in a brand new wiring harness and custom gauges. Which was a big undertaking and I am really happy with how it turned out, but now that I did that, 5 more things screw up. It never ends...
Lets see, my t-case is stuck in 4wd, my passengerside hub got water in it and completely toasted the wheel bearings and somehow caused the 2 lock nuts to grenade themselves, passengerside axel ujoint is toast, my front driveshaft slip joint is so slopped that it gives me crazy vibes, also now out of nowhere my brake pedal is going right to the floor.
So it looks like I am now going to need a new t-case, frontdrive shaft, wheel bearings, spindle, axel ujoint, lock nuts, and a master cylinder.
Rant off
So as it sits now i can't get the hub off. There are little cunks of the locknuts and the bearings that have embedded themselves into the spindle and the bearing can't slide over them. Anyone have any ideas?
Also As for the t-case which is a 208. The foward output is aways directly connected to the rear output no matter where the shifter is. Its not poping out of gear, in fact the shifter and linkage are all working smoothly. I think something broke inside it and now its toast. Opinions?
Rant off
everything was fine til i
