One ton leaf options
SpeedlabDan
Keepin it trashy never classy
Woodstown, New Jersey
So I’m sure some of yoy are aware of my overbuilt dually but I’m getting ready to paint this winter (hopefully) and what better time to address the suspension, right?
So I have the shackles flip I acquired from @sweetk30 a few years back that raise the rear an additional 4”.
The front is still sporting an unknown brand of 6” leafs that ride pretty decent with a big block overhead.
This setup leaves the truck almost level with maybe 1” shorter in the rear even with the tall one ton leaf packs. Yes I hate the squat too.
The plan is to make the truck a little better on the highway. Even with the Allison overdrive the 4.56 at a little short so 4.10 eventually with the doubler shout ensure it’s still very capable.
The other issue in question is the the ride. If you have a one ton you know exactly what I’m talking about. Anyway the hamster wheels of my brain are turning.
What ifffff, I swap to a 3/4 ton rear spring with auxiliary helper bags and lose an inch or 1.5 then I can swap the front springs for a +2” leaf essentially getting the rig back down to a height I may just be able to squeeze under a gooseneck trailer and use it as the tow rig it’s intended for.
Just wanted to see if you guys had any opinion on the idea or personal experience before I dive into parts. I’m already changing the perches on the rear axle to correct the pinion angle and move the axle back 1.5” to correct for the shackles flip.
That’s a lot of work for very little change. Been there done that and I chose to have ORD springs. It is a jarring feeling with any stock rear spring compared to a custom spring. For reference, the tailgate doesn’t sound like it fell off when you go over a speed bump.
If you're up for the work and the expenses you can't beat a softer spring and airbags especially if you plan on towing with it.
As for height I prefer the least amount of lift to clear the tires.
The lower the better
