One tons, big block, NV4500, doubler and more for sale
tRustyK5
Elbows up!
Author
In my garage
1) Dana 60 front, SRW from a M1008. 4.56 gears, low miles, ORD crossover (regular not high steer) with drag link and pitman arm. 1410 yoke, Warn lock-outs. 30 spline outers.sold
2) 14 bolt full floater. Also from a M1008. 4.56 gears, Detroit locker, new pinion bearings, 1410 yoke, disc brakes (no e-brake). $2000.00 for the pair, prefer they go as a set.sold
3) '95 GM diesel version NV4500, Advance Adaptors bellhousing, Hydro pedal assembly, master, slave and line (new) $1100.00
4)32 spline rebuilt 203 range box (NWF) NWF doubler kit, fully rebuilt 32 spline 205 (NWF) billet bearing covers and pto covers, 1410 front yoke, companion flange for CV on rear output, NWF triple stick shifters. $1700.00 for the whole works.
5) Big block Chev, 1990 truck, 4 bolt mains, peanut port heads. Very clean inside, bores look good, turns over freely. Has been cleaned and painted flat black. New balancer, no accessories, no starter. Currently has an HEI dist, SP2P manifold and Edelbrock 1950 Q-jet in good shape. Also have the old stock intake for it. $850.00
6) Big block 781 heads. Good cores. $200.00
7) Warn 8274 project. Complete winch in need of repair, plus a box full of 8274 parts. I'm fairly certain there is enough there to end up with one working 8274. sold
8) 1987 TBI 350. I've driven this one, it has 210,000 km on it. Ran well, plenty of power, but has now been sitting in my carport for a few years. Missing the distributor and some injector parts, but a good core at the very least. Has all accessories. Selling for core value, $300.00
9) SM 465 hydro bell, sold
10) complete hydro clutch pedal set-up for square body GM. Brake and clutch pedals and hanger assembly, clutch master, reservoir, line and slave. sold
11) Custom drive shafts. Built by South Bay driveline in Cali. Front and rear are both 1410/1410, front has 20" of slip, .120" wall tubing. Rear is similar, but less slip joint. Surface rust on tube from sitting in my shed. sold
12) 6.2 GM diesel core. Ran when it was pulled but has been sitting for a while and does have approx 360,000 km on it. J code engine. Core price $300.00
13) ATS turbo set-up for GM 6.2. Complete, but turbo needs a rebuild sold
14) '87 C30 crew cab. as much of it as is left. bare cab on frame. Logger box, 14 bolt with 4.10's. Cab is very solid, and interior is stripped. Outer rockers do have some rust, but inners and floor are rust free. I have the front clip for it, but it's not on the truck right now. Have regi for this. Scrap value is $500, I'll entertain any offer above that.
15) V-bar tire chains, should fit up to a 36" tire. $75.00
16) 2WD GM steering box ported for hydro assist, with hydraulic lines. $175.00sold
All prices are negotiable. No dibs or any other BS. First one with cash in hand takes the stuff home.
I can be reached at 778-245-4485 pretty much anytime. email is [email protected]. If you're interested in anything, come and have a look at it. I don't have time to take hundreds of pictures.
Located in Surrey BC. I'm moving and don't want to drag all this stuff with me.
I wish I had money I would be buying some of this stuff.
I know a truck driver that does trips up and down from Surrey to California and back, if you want to talk to him see if he is willing to take stuff down this way and you are willing to deal with this I can give you his number, it might help if someone down here needs so parts from you.
Let me know.
:waytogo:
3) '95 GM diesel version NV4500, Advance Adaptors bellhousing, 32 spline rebuilt 203 range box (NWF) NWF doubler kit, fully rebuilt 32 spline 205 (NWF) billet bearing covers and pto covers, 1410 front yoke, no rear yoke, NWF triple stick shifters. $2500.00 for the whole works. Will separate but prefer not to and individual pricing will reflect that.
4) Big block Chev, 1990 truck, 4 bolt mains, peanut port heads. Very clean inside, bores look good, turns over freely. Has been cleaned and painted flat black. New balancer, no accessories, no starter. Currently has an HEI dist, SP2P manifold and Edelbrock 1950 Q-jet in good shape. Also have the old stock intake for it. $850.00
5) Big block 781 heads. Good cores. $200.00
6) Warn 8274 project. Complete winch in need of repair, plus a box full of 8274 parts. I'm fairly certain there is enough there to end up with one working 8274. $150
7) 1987 TBI 350. I've driven this one, it has 210,000 km on it. Ran well, plenty of power, but has now been sitting in my carport for a few years. Missing the distributor and some injector parts, but a good core at the very least. Has all accessories. Selling for core value, $300.00
8) SM 465 hydro bell, $150.00
9) complete hydro clutch pedal set-up for square body GM. Brake and clutch pedals and hanger assembly, clutch master, reservoir, line and slave. $150.00
10) Custom drive shafts. Built by South Bay driveline in Cali. Front and rear are both 1410/1410, front has 20" of slip, .120" wall tubing. Rear is similar, but less slip joint. Surface rust on tube from sitting in my shed. $400.00 for pair
11) 6.2 GM diesel core. Ran when it was pulled but has been sitting for a while and does have approx 360,000 km on it. J code engine, intake was port matched and blended. Core price $300.00
12) ATS turbo set-up for GM 6.2. Complete, but turbo needs a rebuild $300.00
13) '87 C30 crew cab. as much of it as is left. Cab on frame, still has a steering column. Logger box, 14 bolt with 4.10's SM 465 and the best part is it rolls. Cab is very solid, and interior is stripped. Outer rockers do have some rust, but inners and floor are rust free. I have the front clip for it, but it's not on the truck right now. Have regi for this. Scrap value is $500, I'll entertain any offer above that.
14) V-bar tire chains, should fit up to a 36" tire. $75.00
15) 2WD GM steering box ported for hydro assist, with hydraulic lines. $175.00
I can be reached at 778-245-4485 pretty much anytime. email is [email protected]. If you're interested in anything, come and have a look at it. I don't have time to take hundreds of pictures. No shipping. No paypal.
if that is the case iceman, I might have to work something out...Im interested in the 2wd steering box.
well I will wait for Rene to let me know if he wants to talk to the guy and if the guy is willing to do this, but he is a nice guy from India and might not mind making some extra $$$ on his way down.
This posting was a direct copy/paste from craigslist. Paypal will be accepted from CK5ers (of course)
Shipping is the big issue, I'm faced with having to be at my new job in Edmonton on April 30/12 and I have a metric assload of other things that need doing between now and then. Iceman, see what you can arrange...if it doesn't burn a ton of my time I'm willing to work on shipping some stuff with this guy.
Original post updated with what has been sold already.
interested in the drive shafts, does the rear have a CV? would the yokes/flanges from the t-case and the axles come with? thanks
Sale pending on those. I'd say 95% sure they're sold. If not I'll let you know.
Yokes from the diff's would not come with the shafts.
As much as I appreciate that, I have arrangements made already. If the buyer flakes I'll let you know.
I do have a CV and companion flange here that he wasn't very interested in, both are new/never used. CV is not a HAD CV, it maxes out at 33 degrees checked with my angle finder, and looks to use 1350 joints (size wise).
Not too late. Had a few calls, but nothing concrete yet.
"V" bar chains are the tire chains you see on big rigs. These are sized nicely for a 35-36" tire though. Epic for snow wheeling. If I find a spare minute I'll snap a pic...
The c30. Engine tranny in it? Will it drive on a trailer? Is there any pics of it in progress? Id like something big to put that set of 5ton Rockwells under. And I love that box.
It's bare cab on a frame at this point. No front clip, one rear door, no motor, no tranny, no steering column or pedals. I do have four really good power doors for it, and I still have the steering column with key for it. It'd have to be pulled out into the alley and dragged onto the trailer. Front and rear glass is good.
It's a good candidate for a 4WD swap because it was a 4 speed truck it has the high tranny hump already...
Call me later if you get the chance.
