one tons with standard H1 wheels?
I have no idea, but the spring pearches had to be moved so I think it was out of a 1 ton. The width is 70". I put the axles under the blazer yeaserday and with the 2" spacer it is a perfect fit. If it was wider I would have trouble fitting down the trail. I will post pictures when the swap in complete.
70 would be a Van width axle. That with spacers will get you 74 total which is slightly narrow than a DRW 60 front. Basically gives you close to the factory stagger on track width between front and rear.
Dik
