Jason4x4
Well, I got a Truggy project from paully383, and I am gonna get it wheeling soon. I am going to try and put as little money in it as possible to get it up and wheeling, then start modifying it from there. The plan is to put a narrowed front clip on it that I already have.
I got a turbo 350 and a built turbo 350 with the deal, but the built one has a busted case, so I am gonna swap the guts into another case and run it. It is going to get a np203 that came with it, and it is twin sticked. I got the pink axles from HOPPER, and they are 4.56 gears, so I shouldn't have any gear issues with the 35's on it. And the roll bar in the back was given to me from a guy at work, I just need to modify the rear supports to go to the frame.
As it sits in the pics I have ~$700 in it, and I shouldn't need any more money to make it wheelable, just some time. It had the passenger slider mostly done, and I got the drivers pretty much done, but so far the only thing that i've done is put the drivers slider in, and put my axles under it with a steering box.
I am getting excited, so here it is.
Are you going to trailer the truggy to the trails?
, turns out it was stuck. I think it had some valves rusted shut. After about 2 hours of turning back and forth and pb blasting the cylinders, I got it turning. SO, I went and got some plug wires and an oil filter, and tried to get it running, but the battery wouldn't allow it.
