destro360
Registered Member
ok here's the deal.. my 87 gmc jimmy has a mild i think 4 inch lift.. springs up front and blocks in the rear im putting a new motor in it right now the other one spun the #2 rod bearing. i have another 78 gmc jimmy 4x4 for parts that im currently picking apart.. from what i can tell the parts truck has a dana 44 up front and a 12 bolt in the rear, my truck still has stock 10bolts front and rear.. i was thinking of running the 52 springs off the other truck on the front of mine for more flex but im not sure where that would put me heighdth wise..
i also was thinking of swapping the axles but decided against it figuring 10b would be cheaper and easier to find...
any input or suggestions would help!! i want to make the most of the parts truck before i sell it off and regret not keeping some parts from it thnx
, now im just curious if i should try to mess with keeping the 52 springs off the back of it and eventually using em on my front??
i was considering removing the sway bar and seeing if it was still driveable without it.. but alot of people have been saying how "great" the 52 swap is up front and the amount of flex you can achieve...
i was just thinking about keepin the springs for later but it will make selling/getting rid of the parts truck harder to do
