if you are buying to do one or projects, I say save the money for gas and beer, there are plenty of guys in ethe area that have them and I am sure at least one is willing to help for some beer, or maybe a BBQ too.
Buy a used bender. There are plenty of guys selling benders for 1/2 what they paid. It's not a top quality bender IMHO, and if your wanting to save but a used better bender like a Pro Tools or something. Just my .02 cents.
. So take it for what its worth. the gottrikes bender is cheap if you have a bunch of metal laying around. but if you have to buy all of it it gets expensive quik. The cage on daves Iron Maiden was done entirely with a bender like the one in the OP. I used it myself and liked it alot. Granted my JD2 is sweet. but its not hydraulic. I got mine to do lots of other projects and start a small buisiness. if i was doing one cage i never would have bought it. the Used route mentioned is a great idea too though.Personally I wouldn't waste my money on one like that. For one thing, it will only make a 60 degree bend in 1.5, 1.625 or 1.750 tube, and in only .083 wall at that. IMO you need to be able to make at least a 90 degree bend. Granted a JD2 or Pro Tools 105 is more money once you buy a die or two, but it will also retain a higher value and be much easier to sell should you decide you don't need it anymore. If that just isn't in the budget, then consider buying the plans and building the Got Trikes bender. it is designed to use Pro Tools' dies. Speaking of Pro Tools, they have a free set of plans you can download from their website, for a fairly simple bender you can also build yourself.
1.75 is the smallest in .120 wall I would use on a cage, and that bender wont do .120. I love my JD2 model 32 its a beast!
Oh, sh*t.... I forgot you had a bender!![]()
Whats the price of a stick of 2"?
I pay about 2.25 per foot, have to buy min 20 ft at a time.
Holy sh*t, that's it!!!?
Pfft... Let's bend some tube...
You got a notcher?
My speedway did a little over 90* and was doing .120DOM the whole time.
Interestingly enough from someone who has used quite a few benders, I don't really consider the less expensive benders like the model 3 and the pro tools 105, top quality benders. So take it for what its worth.
That bender can bend .120 wall, like I said it takes a bit of modding, and it will bend 90* it looks exactly like Zimms bender.
One other big disadvantage to it is it bends the tube wider than a 105 or model 3 would. I didn't look at it again but I think most of those will bend 1.75 @ a 7 CLR while a better bender with full dies will bend it at 5.5 (with the correct die)
If you are planning on building a cage and some bumpers maybe a couple other things, then not really doing much tube work, its worth it.
If you plan on doing your stuff plus some buddies stuff, plus some other stuff later, get a better bender
No notcher!, but I need one
I used to pay 2.40 a ft, but bought enough to lower the price
