jtrapani
From off road design. On the '74 blazer.
Definitely 6 inch. I went with the TC 6" EZ rides up front, an ORD shackle flip with 4" EZ rides out back and I still scrape my 35's on the front rear fenders during wheeling. If you go 4", I bet you regret it and want to go higher later.
By moving the front hangers or moving the back?
Won't moving the center hole place the axle farther forward and thereby change the way the spring functions since it isn't centered? I would think moving the front shackles forward would be the way to go to retain the proper movement of the spring but slide the axle forward a couple of inches.
Huh, I have a 4" ord lift with a 4" flip and my 37s aren't even close in the back. Slight front trimming on the back of the front fender of should I say hammering.
No problems with the back tires. It is the fronts that bury themselves periodically into the back of the front fenders when I am turned and compressed. I have 35's and if I had 37's, I am sure it would be worse. It also depends on the springs and shocks you are running. I have TC EZ rides which are pretty soft and Bilstein 5150's on the Ford shock towers so a lot of available compression and movement.
6".
Gives you incentive to go with a larger tire sooner or later.
6".
think it will be a 6 then. I'll check into 52's also. Thanks.
Cut them bitches open to the inner fender!
But my fenders looks so damn pretty right now..... Actually, I wish there was an easy way to cut them back and roll the edges so they looked normal. Somebody should sell fenders that have larger openings than usual in metal and fiberglass. I've seen a couple for sale but they also bulge out the fender and they look like desert runners instead of stock.
