_______________________________________
update 5/22/12
today I checked my Redtop DD battery...12.83
the yellow top in the Maiden was 13.2 has been sitting with the battery switch off for about 3 mo.
__________________________________________
Update 4/25/13
Redtop in the DD 99-2500...hasn't been driven in a week (driving BART) battery shows 12.3 the phone charger is plugged into the cig lighter (with a small power light on it) other than that stock GM stuff.
Yellowtop for the Maiden is sitting in the Maiden, not hooked up to anything and shows 13.4, hasn't had a charge in months.
My 76 CC has an unknown battery in it, and was on a maint charger all winter and showed 12.6...I have no idea how old it is.[/quote]
___________________________________________
12-19 Update on my Optimas:
Redtop in the 99-2500...hasn't been driven in a month (driving the Rav4 now) showed 12.0...put a battery tender on it for the winter...its sitting outside all winter
Yellowtop in the Maiden is showing 13.2 and hasn't been on a charger, battery disconnect switch is off, but the FAST EZ EFI is hooked directly to the battery still...this was put on a battery tender as well.[/quote]
Update 4/25/13
3/26/14 update:
Redtop in the 99-2500 4 years old now...after sitting outside all winter with a Battery Tender on it, it fired right up...no surprise there, the BT did its job.
drove the truck daily for about a week, let it sit for about a week doing nothing but sit outside, voltage is 12.3...not quite what it used to be, but it starts the truck without fail still.
Yellow top in the Maiden, not quite 4 years old, sitting in the heated shop all winter, without a charger on it, I've been keeping tabs on it about once/month...it show 13.1 consistently...the electrical disconnect switch has been off.[/quote]
Nov. 03.2014
Redtop is still in the 99 p/u....it gets used very little when I got the ole 76 CC doing duty...it has sat outside all summer/fall without a charger on it, and after sitting about 2 weeks without use, it measured 12.4. Still starts the truck without fail.
The Yellowtop is still in the Maiden and continues to sit for weeks or months at a time, usually with a tender on it in the shop, however it has been sitting in the garage for weeks at a time without any attention and measures 13.2 on a warmer day for November!
