ORD 4" Shackle Flip for 73-87(91) 1 Tons
Arrover
N.W. Arkansas
I installed these brackets and pulled the truck out of the garage for pictures twice. Then I pulled the truck right back into the garage so these brackets have maybe a hundred feet on them (not miles). The hardware is brand new/unopened/uninstalled from ORD. With my set-up I ended up with a little too much lift in the rear so I swapped in the 2.5" shackle flip from ORD. These brackets were installed on my truck for about a week while it sat inside the shop. I drilled one hole through the bottom of one bracket where my hitch would bolt to the frame. It will not effect how the bracket mounts or works. A couple of the mounting holes are very slightly ovalled to allow the bolt holes in the brackets to match my frame holes. This won't effect how they fit or function. Again, these are the 4" brackets for 1 ton frames for 73-87 style trucks. Price is $175 shipped. The shackle flip I bought from ORD a month ago cost $28.25 to ship. Shipping is included in my price. Let me know if you have any questions.
