My ORD steering arm is the same as for hi-steer with two TRE holes. From the pics I could find, the drag link goes to the hole nearest to the front bumper. Pretty sure that's right.
So question is: if running crossover, but not hi-steer, which hole on the steering arm does the drag link go in? Mine is in the front hole right now, but if I put it in the hole closest to the spindle, theoretically my steering would be a little quicker with a tighter steering radius (unless limited by knuckle stops).
Any thoughts?
Any thoughts?
