ORD custom leaf spring issue
Yeah the only way that could happen is if you were prying on it directly, trying to flatten spring.
its a cold steel rivet . it was not the correct length or hammered over correctly .
fairly easy fit if you know what your doing and have a way to compress and take apart the spring pack . if not a local shop can fix it for you . nothing special .
i use to do these years ago when i did a small stint at a spring shop .
So tapping it back it the hole and tac welding it is not an option ? Lol
Are the springs bolted to the axle yet? When you crank down on the u-bolts that will flatten the springs quite a bit.
the leafs are spring steel . the clamp and rivet are soft steel . 2 types of metal . and even that it takes lots of skill and special rod to weld spring steel .
its easy if the leaf is out of the pack and the new rivet is ready to install. its a sandwich and then hammer the end over flat no high spots to run the bottom of the leaf above it .
but this like i said is not a job for a total spring newby . . the leafs clamped together with the center pin are a loaded gun just like a coil/strut unit .
call ord or alcan and ask how they wish to handle this problem . if it was installed correctly it should have not come out .
That is what I said
so what happened?
So I called ord today and Steven wasn’t in . I called Alcan since he wasn’t there and talked to the owner bill I told him what happened he said it’s no big deal we will send you another rivet and you can replace it . I asked if it affected performance he said no all they do is keep the springs square .
Most everything was covered but:
Clamp the axle to it, that does go the correct direction and may be enough.
Sometimes you can do some clearance grinding on the shackle to get it to fall a little farther and that helps, not a lot but it's the correct direction. Usually the shackle will swing all the way down anyway.
A ratchet strap around the eye to pull it back works sometimes.
We have some screw jacks that we use to push the eyes apart on some of ours. They're basically a bolt and nut welded into a piece of tube to spread the eyes a little.
This is why we don't build a 6" rear lift spring. They just get too hard to install so we integrate the shackle flip.
Thanks a lot for all your help really appreciated ORD is a great company and wants to help their customers!
And one more thing - if you have to remove the springs for any reason, make a spreader and put it between the eyes as you droop the suspension. Then when you put it back together they're already spread out. We use a piece of tube with the ends cut with a little angle to help hold them in place between the eyes. something like this /--------------\. A piece of 2x4 would do the trick, it doesn't have to be fancy.
