Would like to get some input from people who ether have or have experinced ether of the set ups. Iv been doing alot of resurch on the two and am completely torn which way i want to go when the time comes. Each seems to have its advantage/disadvantage both with instal and performance Currently I have a rough country 6 inch lift, all spring in the front and 2 inch lift springs with 4 inch blocks in the rear from the p.o. I really dislike having blacks that big in the rear (yes i plan on shackle fliping the rear in place of the blocks) and the flex and what not is crap, even on the littlest amount it seems like there's more body flex then suspension flex. The idea suspension wise is to have the truck be able to go where ever I want, on the street or dirt doesn't matter, just want it to be able to get there. Currently I'm pretty settled on/torn between doing ether 52 springs or Ord custom springs up from with 56 springs in the rear. From what iv priced out both ideas seem to not be that far apart price wise considering I'd be beefing everything up along the way. I know going with softer springs will cause more body roll then what i have now but im good with that being used to my cousins jeep which has a pretty good amount. Any thoughts on which way you' go and or what you would do differently with the instal if you have ether set up would be appreciated. Thanks guys.
