Same.Yes on long barrel.
I've had the long barrel hit them hard enough that the head popped off so fast I thought the chisel slipped, but looked and rivet was gone.
I have been reading and thinking the same thing. I got a Matco long barrel back in 2012. It will take the heads off without any pre cut being done, but it will shoot the head across the garage that way!If you have enough air and the Snap On badass air hammer those rivets will blow off like cutting a piece of cheese with a knife. I spent the $400 about 6-7 years ago and have never regretted the purchase. Took me about an hour to remove every rivet on a K5 frame.
I use my plasma cutter for that it's the easiestI watched a YouTube video showing a guy using a plasma cutter to remove a body mount off a Ford Explorer frame,and I must say it appeared to be the quickest,easiest,and least damaging to the part your trying to remove intact,next to drilling...drilling is tough when you have no lift and your over 60 and in poor physical condition though..
Yeah the plasma cutter is even easier.I could have probably borrowed my friends plasma cutter--but due to my fuel tank leaking a few inches away from the rivets I had to remove,that nixed using that or anything else with a flame or made sparks like a torch or a grinder..
I've never use a plasma cutter yet either,I'm sure there is a learning curve too...I used to be good with cutting torches as far as lopping off bolt heads,nuts & rivets without ruining the part they held on,but not so much lately..
