I normally dont get any pictures on my wheeling trips either. I get too dang excited about whats going on and forget to take pictures of it.![]()
I was watching the video on the UA, and noticed a lot of the vehicles don't even have fenders and the tires are completely exposed! I thought you had to be street legal? About the mtrs.....are they better then super swampers?
given the choice of building this setup again.
(other than for marketing purposes of selling SAS kits)
would you still go leaf or look into linking it on coilovers? any thought to making a 3 link setup for these trucks?
on the same line of questioning, where the low lift clearance became an issue, do you think going linked setup would have helped/alleviated some of those issues?
thanks-
Thinking of doing a SAS on a 93 Chevy C3500 and wanted to see some more details of this truck. Reread the whole thread to find you used 47.5" front springs. Is this for handling purposes? Where can I find the springs you used on this and how much do they cost?
I have read other threads where a track bar is advised with 52" front springs. Do you make a track bar for your SAS swap?
On the ORD site, you mention the differences in frames (thanks). Have you seen your ORD SAS kit modified to fit a 2wd 3500 frame?
Thanks for the input.
Any thoughts as to the addition of a sway bar? I saw on your site where you sell shock mounts (frame end). Is that what you would use for this kit?
This truck is more of a street truck, being that is a crew cab. The HP60 and the NV4500/NP241 are already here. Just researching to decide between the 52s and 48.5s (thanks). I would like to keep it just tall enough for 35s for now. Maybe 37s later, depending on how the gear ratio (4.10s) works out.
Any feedback on how this ORD truck rides and drives? Is there any thing that you would do different?
The ride is way better than your average leaf sprung truck. The combo of ORD springs, King shocks and air bumps is great. There hasn't even been any shock tuning done so I think the ride can only get better.
The rear suspension on this truck was kind of experimental with the spring length and arch. I know Stephen changed the rear springs on it this year to get rid of a weird handling issue that was happening because of rear axle steer due to the spring arch etc. He said it was much better, I haven't driven it lately so I don't have good input. Bottom line is that the only issue with handling was found to really be coming from the rear not the front. In fact I was driving it when we found that.
I was going through 2'+ deep water bars and the front just soaked them up and felt great, when the rear hit them I had to counter steer and it caused a bit of a squirrely feeling. It was taking the water bars at 25+ and not launching into the air
I wouldn't put a set of 52" springs up front. The ORD custom springs can match and exceed a 52" "stock" spring pack, without the goofy overhang and stupid axle wrap issues.
I've got 52s in the front of my truck and would say that my steering quality suffers the most becuase of them. I have hydro assist, but deal with a lot of slop in the system due to the steering box pushing / pulling the axle side to side. I have an all new steering system and have done a bunch of bracing on the frame, so I really don't have anything else to blame.
I thought that the 52s were also causing problems with handling (wollowing around under load at speed in a harmonic ossilation), but after making use of my go-pro camera, I can see that it is more and issue of body roll and crappy shocks vs anything else. If I hit a bump straight on, the shocks don't let the truck bounce at all, but if I hit a bump that throws the body to one side, it is too heavy for the shocks to absorb all the energy and it gets to wollowing around.
I am going to start with a disconnectable swaybar to see if my handling improves any and if it winds up that I really do need new shocks to fix my at speed handling, I'll be swapping in a set of king coil-overs with a 3 link to also eliminate my axle wrap / steering slop.
If I was to start all over again, I'd not have cut out the original IFS crossmember to avoid having to beef up the frame so much, and I'd run the shorter custom springs to fix all the handling / steering issues I've had to deal with.
