Out of blinker fluiid???
85 Shortbox
Grandville, Mi
My turn signals one day just quit working, I changed the blinker relay and it still does nothing. Oh yeah the hazard lights do work. It is a 92 S-10 4x4. Any ideas? Thanks guys.
check your fuses and make shure the blinker you replaced was your trun signals and not your hazzard blinker (both are the same though)
ohhh ohhh... what i was lookin for... i have a 1996 and cant figure out where the blinker is... my fuses are ok and my hazzards work. But i dont even have turn signal lights show up on the dash?!?!?!?!?!
its the multifunction switch, pull the column trim off and look for loose wires at the back of the connector for the multifunction switch (what controls the wipers and turn signals...), if all the wires are ok.. check to see if all your brake lights work.. you can pm me if you need any info...
