Yep youngsters, learned alignment from the computer on the machine.
We older fellas had a tape measure and some string, maybe a caster camber guage.
I must have missed the post with results from the shop. Did they give the actual caster measurement?
The reason I ask, is there is probably going to be compromise. When you start modifying you have to make choices.
It is tough for some of these "Front end" guys to figure it out when the computer can't tell them.
After you get it back check your u bolts and retorque as nesassary.
