Got a question for you transmission gurus. Had a 700R rebiult recently and it has no overdrive. Is this major parts failure or is there an easy fix for this?
Did you set up the shifter on the column again when you put it back in? It's easy to get them a bit out of line and only have it in D even though it may indicated OD on the dash. Check fluid level again and set the TV cable as per instructions at www.tvmadeez.com article 101 at top of page.
