joshkbomb
I put in a new water pump, lower radiator hose, and belts yesterday. Now the truck is overheating (at least according to the gauge). It's an '87 Blazer with a 350.
Things I've done so far or suspect:
1) I was having overheating issues this summer that were probably caused by an air bubble. So this time I went through the refilling process carefully and burped it a few times. Still overheating. I'm not 100% sure all the air is out, although I don't hear gurgling in the heater core anymore.
2) The thermostat is only 5 months old and was working fine before I did the water pump. I'm assuming it's okay.
3) I may have put the wrong rotation water pump on. I have V belts (with the one serpentine for the alternator) and assumed the standard clockwise rotation pump is the right one. I put in Napa PN# 43099p. Is there a good way to verify it's the right direction without taking everything apart again?
4) When the gauge is reading 260, the highest temp I'm getting with my infrared thermometer is next to the temperature sender on the side of the block at 235. Thermostat housing stays at 160-180, radiator and hoses about 100. This happened to me this summer too when I spent a few days diagnosing the gauge only to have air come out of the system and the gauge start reading normally. Very confusing.
. May just be me,but that sounds baaaad.
