katugly
So I replaced my OEM radiator that had more leaks in it then were repairable with a new one. Proper 3 core with HD trans cooler and such. The shop guy noted that the T-stat may be stuck open or not installed. I cracked open the housing and it did have a T stat in there but it was stuck open. I dropped a new Murry in place of it but the sonva bitch wont open. I pulled the upper hose and when the gauge on the inside is damn near into the red the upper hose is dry. I pulled the thermostat out and had the wife start the car with without it and it pumps out no problems. What would make a new T-stat that has been tested in water to be good not open in the car. What is the best way to bleed the system because that's the only thing I think that could be the issue is there is air trapped under the thermostat. 90 blazer with a 350 btw.
