OX locker or ARB locker... opinions? comments? suggestions?
newboy89
Ny
guys and gals, i think the title tells it all... what do you guys think? the differences in perfomance, usability, afforability, quality, etc. thanks in advance.
-charlie
Is the OX Locker available for your differential?
<font color=green>Today's Forecast: Partly cloudy with a chance of mud</font color=green>
yes i just picked up a d60. i am going to have it rebuilt with the locker in it so i wanted to know what to use.
They sell the Ox Loxker for a Dana 60?
I thought it wasnt out yet?
Do you know the cost on it?
Ken H.
'86 K5 in parts
1-ton 44 TSLs
454 BBC, 350 trans, 205 transfer
Rust free in Michigan!
They are making them for the D60, but it's not out yet (Ox). But I emailed the guy a while back and he said estimated cost is about $1500!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So, I went with the ARB instead. It's proven for the D60 and is reliable for that axle.
Boss
Pic of my truck Before N' After
<a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
Personnaly I like the OX better than the ARB. Less to go wrong. When your figuring costs you need to add in the cost of a compressor to run the ARB.
The ARB has so many places it can fail. I have seen blown seals, bolts loosen up. ARB say's this was not a problem but they tell people how to dowl the housing to prevent it and changed a few other things. May not be an issue now as these upgrades should be on all new ARB's. They are very easily damaged by any dirt either comming down the air line or in the oil.
The OX is just plain simple. It has a locking collar that has a fork like a tranny and it simply is slid into place making it a spool. The ARB does the same thing but it uses a very delicate air piston to do the job.
The only vulnerable thing on the OX is the cable but the air line is just as vulnerable on the ARB. It doesn't require a compressor, solonoid valves, wiring and all the failure that can happen with that.Just a simple cable like a bick shifter.
Women dig dents and flat paint!
coloradok5.com/gallery/Grim
75 Jimmy, Dollar
Grim-Reaper
