Hi - This needs to get painted badly. The white paint runs down the side when ever it rains. What paint do you recommend? Could I just roll it on or do I need to spray it? Should I sand it down first?
and if you go the rout im going satin black
(not my rig)
not bad for $30 tractor paint
That is the exact color I need. Where do I get this satin black tractor paint?
Edit...Found this: http://www.amazon.com/Valspar-18-4432-19-Tractor-Implement-Enamel/dp/B00467AKFI
I've been thinking about just doing mine with bedliner...
Well bedliner would be good too, but I just used the undercoating they spray on inner fenders and the bottom of some trucks on the rockers.
Cheap and easy and came in a spray can.![]()
