I might consider that too...it is cheaper than bedliner, right?![]()
Depends, these days they have herculiner I think th ename is? at Walmart for really cheap, comes with the roller and everything.
.i dont have much money and it took 3 to 4 cans to get good coverage.as was said you need to get that old paint cleaned off and then reprimer and paint.you can rollon bedliner and ive seen it look pretty good on some peoples trucks on here.it is 80 bucks a pint though and i dont know how much you would need.4 cans of white spraypaint is 15 bucks and as long as you take your time and spray it right it will look good.tape off the windows good beforehand or take them out.get some maroon scuff pads and scrub the pee out of it with soapy water, rinse... you'll want to spot in some primer at least over the raw areas....
May be a little more expensive, but I remember about 20 years ago when I painted my 78 Corvette(sold) I added a "flex additive" to the PPG automotive paint I used. I was informed by "dealership autobody repairman" that it was crucial as without it the paint would eventually crack from all the flexing the fiberglass does. Don't know if it is necessary with today's high performance coatings, but may be worth looking into.
Also you might want to look into the marine paints as there are allot of fiberglass boats out there. (MAYBE RYOKEN CAN CHIME IN HERE.) As far as making it "flat" or "satin" I believe you can add something to the paint to accomplish that.
