K5dreamer
Ok, so ive started looking at what all parts i need to do the disk brake swap on my D70HD. And ive noticed, most sites list the 1975 3/4 ton front brake calipers and rotors as the ones to use, because they fit, and they are cheap. My question is, with 4 front brake calipers and rotors.... how does the parking brake work?
Ive read a few things about "caddilac" brake calipers, but no mention of application or where to get them, but it does seem that they are much more expensive. There has to be some other application that would work. What about the newer trucks with 14bff rears, wouldnt the disk brake setups from those be a relitively easy swap? and still retain the ebrake setup?
Its not a huge issue for now because i still have the TH400. But i do plan on doing the NV4500 swap at some point and will need some sort of emergency brake. Pinion brake maybe?
Im doing more reading as you read this, sitting on my bum at work, but figured if someone here already knew, it would save me some time.
