G
goldwing2000
Guest
drivelineman said:![]()
I run my t-case e-brake -JEss
Well, yeah... of course you're running your own parts, Jess!
I'll be running your parts, too (once I get my tax refund).
JEBSR said:The mechanical type just means that you turn them on and off by hand (mechanically). Will not disengage until you manually turn it off or depress the pedal again, depending on what style you use.
Electric type just basically uses an electromagnet to push/pull the plunger to activate it. Only problem with these is that as long as it is applied it draws power from the battery. If used to long the battery will die and the line lock will release.
You depress the brakes and activate the line lock then let off the pedal. This keeps the fluid from returning back thru the lines into the m/c causing the brakes to remain locked.
4X4HIGH said:Factory rear eldo calipers and hooked up and working.![]()
muddybuddy said:how well do those work? ive got a pair of caddy's that im going to put on my 14b. from ppl ive talked to they said it didnt work that well, maybe their linkage was not tight
ntsqd said:These are obviously short term only since they draw some considerable battery power to keep the brakes locked.
38377k5 said:I have known two people that have had the caddy calipers and neither really likes them despite tons of fiddling with them. One has switched to a t-case emergency brake.
bp71k5 said:I've got the caddy calipers too and the ebrake works just fine. You do have to use it every once in a while to keep it adjusted properly.
To be long term (overnight or longer) it'd have to be in the milliamp range of power draws.38377k5 said:Mine (electric roll control/line lock) uses a 5 amp fuse which means it probably only draws 2-3 amps which doesn't seem like all that much to me
Of course, I have never left mine on overnight.
