Parting an 87 2wd Suburban
FightinTXag
Fort Worth, TX
I took the TBI 350 for transplant. No rust, good body panels, tan interior complete in decent shape. Rollup windows,
Tailgate w/ power rear window, no defrost (I think).
Non-tilt column w/ delayed wipers w/o cruise.
Receiver hitch.
Instrument cluster (gauges no clock) - shows 47k mi. Everything worked when I pulled it.
2WD 700R4 - 1k mi since rebuild, includes new torque converter. $400 pickup only.
Also willing to sell the rolling body & chassis. I have the title.
Let me know what you need. I'm going to have this thing hauled off before much longer.
Also parts taken off my '85 to make room for the TBI 350:
Q-jet from '85 w/ 305 (non-CCC) - Includes new idle stop solenoid for a/c idle kick up ($70 from Oreilly), choke pulloffs and accelerator pump. Electric choke works great. I rebuilt it, but never got the thing to run perfect. Never figured out if it was the carb or the ESC HEI dist.
Complete 305 from '85 - Bad rear main seal, bad valve stem seals. Good for core.
Starter, alternator, and PS pump from '85 305.
Nearly new big HEI dist cap & coil from '85 305.
Intrested in the Cooler, do you still have it? How about a drivers side armrest? Condition?
I could use the window channels in the tailgate. Also the bolts to hold them in.
Let me know. Shipped to 32506.
90k5blaze,
I just checked out the drivers side armrest. It's in pretty good shape. Looks like there is some grime down in the texture grain that could be cleaned up. And the texture has been worn a little smooth in some areas. But it's not split or deformed or flattened like mine is.
I still have the oil cooler setup too. If you want both pieces, I'd send them for $70 (shippin included).
84zz4ss,
I'm a pickup guy so I don't know much about that tailgate or it's window assy. What's involved in pulling the run channels?
did this get taken away yet? im looking for exterior mirrors, dash bezel, and tailgate channel as well!
Passenger mirror has a pretty good dent in it - probably not worth the cost of shipping.
Drivers mirror has some scrapes on the very edge of it too. If you want it, I'll just take $10 to cover shipping.
Dash bezel is in pretty good shape. It's not show worthy, but it's very nice. I've zoomed in on a couple of white spots near the PRNDL indicator and you can see where the chrome-looking paint is worn near the a/c vent. I'm keeping the A/C vent itself. $90 shipped?
The tailgate channel may be spoken for. The felt is toast, and I'm having a hard time figuring out how to lower the glass without any electricity so I can open the tailgate to remove the channel bolts. If 84zz4ss doesn't want the channel, I'll let you know.
how complete is the body, interior. I am looking for a body to swap out with my 76. Really looking for something with a semi good interior. Tan would be great. Really needs the 3rd row seat and all belts. Body can have some minor dings and paint job really don't matter. I will have it painted within the year.
So how much for the rolling body and chassis? I live within an hour or so from you if you are in Ft Worth so pick up is possible.
Let me know.
Body - Both bumpers are bent & dented. The rt front fender has a crease where it looks like the bumper was pushed into it at some point. The rt headlight bezel is cracked in this area too. One good sized ding in the hood - looks like it came from a baseball or something. Tabs are broken on the grill. Otherwise it's straight and rust free with faded red paint.
Interior - I had to tear up the driver's door panel to remove the armrest for 90k5blaze (PB Blaster wouldn't free up the rusted pull strap screws). Of course the armrest is gone. Drivers seat has a tear. Dash pad is cracked. Dash harness is gone for my TBI swap. One of the rear door panels is cracked. Carpet is very very nasty. There is no 3rd row. Front seat belts work fine, never used the back ones.
You could have the titled rolling chassis & body for $400 since that's what Pick'nPull has offered. You'll have to act quick if you want it though. The wife is tired of it being in front of the house.
Thanks but I will have to pass. I think I have a lead on an 87 with interior in excellent condition, straight body, and good tranny for $500. motor still runs but needs overhauled. I thought I would check though, rather support the brotherhood first.
how much for the driver seat belt retractor? shipping to 90504.
pm me if you don't mind.
