Parting out 1987 1Ton on 42's - So Cal
Do you have the dash pad? If so is it in decent condition?
Also, is the brake booster vaccuum or hydro boost?
I'm interested in the h1's. Are they recentered or just stock? do they have any incerts or anything? Are you willing to ship, and will you add that to the asking price, or will that be included in the asking price. Let me know. Thanks!!
They are not recentered, and come with the mag inserts and 5 new o-rings.
I don't have the time to deal with shipping right now, but if you can arrange for a shipper to come get them I'd be willing to remove them from the tires.
I do not have a pallet or boxes for them, so that would all have to be figured out.
I'm looking for a passenger side OEM inner cab corner for 73-87 Chevy or GMC pickup. If not the majority of it, I would settle for the inboard vertical feature adjacent to the fuel tank. This feature is not included with any repro. I will provide image. Anyone got a junk cab around they can cut this off for me for $?
Also looking for very clean original steel non-A/C heater blower motor housing, engine bay side.
Images of RH inner cab corner. The entire inner cab corner goes from rear shelf to bottom of outer cab corner and rocker panel. It may not be practical to remove the entire panel. In lieu of that, to cut up to within 1" of door jamb rubber bumper, including inner and outer cab corner with 2" of the end of the rocker, I could work with it, splice in and weld. At a minimum, I'm looking for the feature that sticks out past the cab corner adjacent to the tank area, up to and including the weld flange. See images.
I have some rust there on my cab, so let me take a better look at it and I'll post up a pic to check if it would be usefull to you
Here are a few pics
Well, not mint but I can probably work with it. I don't care about the outer cab corner. You understand the feature I'm looking for, correct? It is fairly evident in the top image I put up. If you're willing to cut up above that (half way up inner) and into door jamb, include the plug and shoot me a price shipped to 03839...
Thanks!
I don't exactly understand, so I'm going to go put some blue tape at where I think you want me to cut and I'll post a few more pics up.
Give me 5 minutes...
I think I understand now after looking at your pics a few more times.
You just need the inner piece that has that plug in it right?
