Parting out my 1979 Chevy Blazer
Tonyraca
Registered Member
San Jose, CA
Had no luck selling the Blazer whole and I'm taking the TH350 and NP203 out to use in a doubler kit for my '72 so everything else must go. Here's a list of what I've got ready to go so far, but if there is something specific you want let me know and I might be able to get it taken off before I scrap what left. If you want additional pictures let me know. I am sure I’ve missed stuff that’s also worth parting out so let me know what else you might be interested in and we can discuss.
I’ve got some “suggested” pricing, but everything is OBO! +shipping…make me an offer I can’t refuse!
ORD Bolt-in Steering Box Brace Kit $130-->$60 pending
http://www.offroaddesign.com/catalog/steeringkit.htm
ORD Competition Style Motor Mounts $170-->$80 pending
http://www.offroaddesign.com/catalog/motormounts.htm
ORD Swaybar Correction/Disconnect Kit $99--> $60 pending for bushings and kit (missing one cotter pin and replaced with bolt)
http://www.offroaddesign.com/catalog/swaybarkit.htm
ORD High Clearance HD Engine Crossmember $189-->$100 pending
http://www.offroaddesign.com/catalog/enginecrossmember.htm
Painless Performance 18-Circuit 1973-87 GMC/Chevy Truck Harness $630-->$300
http://www.summitracing.com/parts/prf-10205
LMC Replacement Door Panels $169-->$100
http://www.lmctruck.com/icatalog/CSB/full.aspx?Page=136
LMC Replacement Carpet Set $329-->$150
http://www.lmctruck.com/icatalog/CSB/full.aspx?Page=127
TSM Rear Disc Brake Conversion 14-bolt $299 (in its original packaging)
http://tsmmfg.com/2630E.htm
TSM New Rear Calipers $320 (in its original packaging)
http://tsmmfg.com/3120.htm
Full set of Wheel Studs and Lug Nuts
Got dual 3” exhaust from Hedman Hedders through Dual Catalytic Converters and Flowmaster Hushpower II mufflers.
Original Stock Parts (make me an offer)
Sway-bar
Rear Roll Bar
Spare Tire Carrier
Rear Bench Seat
Rear Bumper Braces $20
Rear Bumper
Dash Pad
Trunk Side Panels (pending)
Gas filler cover
Center Console
Interior Cab Molding (white)
Visors (white)
Trailer Hitch
Radiator
Air Cleaner
Dome Lights $10
Stock Gauge Cluster (no Tach)
Gas Tank $140-->
Gas Tank Straps $30-->
Gas Tank 4 Outlet Sending Unit $70-->$150 for everything
Offroad Design Quick Disconnect Kit + Bushings
Drop Pitman Arm 4"
Stock Rear Bumper Brackets
Stock Center Console
Tail Light Fixture
Carpet (Have the front carpet and wheel well covers as well, just need to get some more pictures posted)
Vent Ducts
Door seals
Edelbrock Air Cleaner (Round)
Edelbrock Air Cleaner (Triangle)
Trunk Spare Tire Carrier
Door Panels
Front Grill
TSM BRAKES
Miscellaneous Door Pieces
tony, I definitely want the tailight assy's, the ORD steering box brace and frame reinforcement stuff.
can you describe the following items a little more:
1)center console, I see it needs a bit of a paint job, but any cracks? Latch mechanism there and working? Price for it?
2)What color is the dash pad, what shape is it in? cracks, or peeling at all? Price?
3)Door seal description of what you have there? Prices?
76zimmer,
PM me your email and I can send you some additional pictures. The brace is still on the truck and has to be removed still, but should be off by the end of the week.
How much for the full set of lug nuts / studs?
Will they work with 10bolts from a 87 k5 with stock rallye wheels?
I will take the ORD bolt in brace as long as its 73-80 style (if not already taken), pm me shipping quote to 12019
EDIT: also would be interested in the metal interior molding that is above windows up front, just the driver and passenger pieces, they are like 12" long or something, thin metal.
Very interested in the ORD swaybar disconnect kit with the bushings.
How much is shipping to 59101?
Working on responding to PM's
Will update the first post soon, but here is what is sold/pending.
SOLD
Weld-In Frame repair kit
All replacement weatherstripping
New Tail Light kits
PENDING
Bolt in Steering Brace Kit
Swaybar Bushings
Arm Rests
Drop Pitman arm
I am swapping the 350/203 out of the '79 to fix the SM465 in my '72 and do a doubler at the same time. Once all is said and done the only thing left is going to be the body on the frame.
The only things worth anything on that will be the ORD shackle Flip and extended shackles that can't really be taken off, and the gas tank with a brand new fuel sender. Has 10b/12b axles with 33" BFG AT-KO's on 15" 6-lug stock wheels.
Pacific Fabrication is working on my '72 and I was just going to give them what was left as a scrap container. They basically fill it up with all their scrap metal and sell it by weight at the dump.
If someone is serious about wanting the body and frame then they better jump on it quick because it'll be gone in probably a couple weeks. You'd have to get to Morgan Hill with a trailer to pick it up.
BTW. I do have the title.
Any passenger side doors ? I am in need of one.
Ill take the cross member I can get it on friday
What do you suppose the chances are of talking you into pulling the shackle flip and shakles? I realize that poses a challenge but thought i would ask. Thanks
Chances are slim. Won't be able to move the truck around without those parts. It's really not worth the trouble.
I am interested in the body and frame.
I will talk to you via pm and yes I can pick it up at their shop in morgan hill.
Heightsian and garage wheeler. One day the project will leave the garage.
South-sider down by the coal plant and KOA.
Mine is doing duty as a "daddy wagon" for my 2 girls, one 4 years old, one 6 months old, but I have a Rough Country 4" lift I'm installing in about a month when the weather cooperates a little.
