sheepdog_tx
Registered Member
Got an 83 4x4 with 700r4 and 10bolts front and back. Not sure which seal I need, autozone has a few choices. Also not sure what size socket i need of pinion bolt. Besides the seal and gear oil what else do i need?
You ought to ask autozone if they have an in-lb torque wrench for loan when you are talking with them. It's not a tough way to get the pinion just right either.
When at autozone, I'd just see which socket fits. I'm almost positive its in the 1-1/16 to 1-1/8" range.
Mu autozone is in what you might call a "sociology-econonically challenged area" and therefore has almost no tools to loan due to theft.
They will loan them out if I know exactly what i need an leave my driver's license so I would be helpful to know the size if anyone can pin that down for me.
BTW on gear oil what weight is recommended?
checking pinion bearing preload (with an in/lb wrench) wont work with the carrier installed.
I somewhat wonder what was left out of the method GM prescribes for in-lb in the manual, as they don't talk about removing ANYTHING before measuring preload.
Why won't that work with the carrier installed? I assume their rationale to be that the amount of torque required to turn the pinion (regardless of what's attached to it) won't change as long as everything is the same at assembly and disassembly, outside of the seal of course. And they do specify to increase that measurement slightly upon reassembly, I'd have to look again for that spec.
With brakes, when talking in-lbs, I don't think I'd risk having them drag. Already opening the diff up somewhat, not a whole lot of extra work to take the cover off and pop the axles out. Which is never a bad idea for inspection purposes anyway.
