K5dreamer
OK as yall know i got the D70HD rear end for the Blazer. and ive decided to go with the 3/4 ton brakes for the disk conversion as ive heard bad things about the caddy calipers, and finding a set of mechanical calipers to do the deed is too much trouble.
SO, i went to the junkyard today to find some other parts. and low and behold there was a parted out suburban in the back. so i checked it out.
1987 2500 sierra suburban 4x4.
no idea what engine it had (long gone), it does have the 8 lug rims front and rear, the rear axle was a semi floater. but i didnt crawl under to see what it was. front axle was a non locker, or auto locking hubs.
The guy quoted me $50 for the calipers, rotors, and brake lines. think i should nab em up?
how hard is it to rebuild these? anyone have part numbers for kits?
are these the only things i should get? am i missing any critical piece's here? i dont think i need the backing plates, or mounts, as ill be ordering the conversion mounts to put the calipers on the D70HD axle.
Thanks.
Thanks.
