NOT my regular camera but my cellphone this time....went looking at two yards today...almost gone...I have picked both of these yards over the last few years and there are less and less every time I go back...
You have to go back there asap take some wd 40 ! Look at the suburban.
I need these before the end of month! If it have a good switch inside for rear window I need the rocker part. mime has a hole in it and I get shocked.
I thought about you when I was up there but I know next to nothing about Burbs and different years. I'll go back and check (if it is still there)
Where is the switch located that you are looking for...tell me what tools I need to take (I left home without a philips screwdriver and was cussing myself)
Spray them with WD and let it seep into the titty. Then with a slight pulling and turning motion pop them out. The bracket has one screw not sure of size but small socket set should get it. Here is the bezel from the back side screw is at the bottom.
