sandawgk5
3/4 ton status
I just had to go get a smog test again, my every other year one, and I passed but my HC at the 15mph test were 119 PPM the max is 120. At 25mph the reading was 64 and max is 97. The rpm for both was between 1500-1600. The CAT is only about 2 years old and has maybe 500 miles on it in those 2 years.
The question I have is what could be causing my HC to be so high at low speeds but drop off at the higher speed even when RPM is the same?
If more info is needed I can post up the other numbers from the print out.
Oh timing is 1 btdc, 87 oct, temp was up around 190 and has a stock thermostat, and this is all on a bone stock 87 350 with about 180,000 miles on it.
Dik
Dik
