goathearder
Update, solved. See below.
Hey Guys,
I have been troubleshooting this passenger rear turn signal of mine (which stopped working the other day) and I can't figure out what is wrong because everything seems fine. Here is what I know:
1) Flashers are new
2) All signals work except the passenger rear
3) Bulbs are new and passenger rear bulb works when I move it to drivers side
4) Passenger rear socket IS getting 12v (volt meter goes up and down with flasher)
5) Tested continuity of bulb body to ground with bulb in socket and its good.
6) Parking lights work FINE on the passenger rear (and everywhere else)
So, socket has power and ground, bulb works elsewhere and every other turn signal flashes just fine.
I am thinking maybe the bulb isn't making contact in the socket although that seems unlikely since the parking light portion of that bulb works. Could it be shorting out somewhere with the bulb in cause I only measured voltage with the bulb out?
Any ideas?
Hey Guys,
1) Flashers are new
Any ideas?
