Correct me if im wrong, But the "preloader" it the top balljoint, would cause +/- caster if screwed further in our out. Why wouldn't it? Screw it in= more caster Screw it out = less. Makes sense to me cause of this,
I realize that its not eccentric, but being that the upper BJ is further inboard and not straight up and down, (emphases on the not straight up and down part, then screwing that in or out would move the upper BJ(ever so slightly) further in/outboard. Right? Or am i high?
Also i meant camber... My bad.
Thanks, all!Ok, just fixed the problem. Looks like my axle did have a shim on that side, and I just thought it was some sort of spacer ring - not realizing it was tapered. It was up-side-down, with the narrow side of the shim pointing down instead of up. I switched it around and have a straight wheel.Thanks, all!
This time it popped free and I put in on 180* wrong.
at least its good.now it wont wear out your tires uneven until you get that 60 under there.its always the small details that getcha.well, I think last time I had the knuckle off, the spacer stuck to the knuckle so I didn't notice it.This time it popped free and I put in on 180* wrong.
