muscle
all concrete will crack. are there contols joins tooled or cut in the concrete slab? there should be a control joint every 10 foot square. this will help control the cracks to hopefully crack within the control joint. on a shop floor i prefer to have the concrete saw cut versus hand tooled like you normally see on sidewalks, etc. this is much nicer when on a creeper or rolling eqipment around as they dont snag on the joint.
I have poured alot of fibermesh concrete and it has performed excellant. make sure you pour at least 3000 PSI with fibermesh and air entrained. start with a 6 slump but be careful adding water as it weakens the mud. if you plan on having large equipment on the slab such as backhoes, tractors, etc the tie in a rebar matt no greater than a 3' on center grid along with using fibermesh. Use a minimum #3 rebar but if you can afford it go with #4. also make sure your subgrade is compacted and do not use an expansive material. i have seen people use a low grade ABC that has alot of clay in it. If moisture is able to migrate under the slab it will cause the subgrade material can expand and heave the concrete.
