I’m looking for some good fitment pics of airbags on these trucks. Manufacturer literature isnt cutting it. Ideally with a 4” lift spring but that’s easy to work around.
I put lower spring rate rear lift springs so I need these bags as a helper when I put a shit ton of crap in the bed or pull a trailer.What is the purpose of putting bags on these size trucks?
Airlift appears to have what I call a better upper bracket. Probably negligible between ride rites and airlift but it’s closer to how I would build my own.I sell AirLift kits all the time at the shop. 88237 is the 5000 pound rated kit for a K30 with the internal bump stop. They have a 7000 pound bag too.
I usually pull up the install instructions for them on air lifts page but I can’t see them on my phone. It usually gives a good idea of how the kit goes on the truck.
LoadLifter 5000 Ultimate Air Spring Kit - 88237 | Air Lift Company
Air Suspension and Air Managementwww.airliftcompany.com
They also have bolt on spacers to accommodate lifts too.
We’ve installed both the Firestone setups and the Airlift. I personally like the Airlift setup better. The Firestone brackets seemed like they were more complex than needed. The bags themselves are probably comparable but the brackets/install are better with airlift. The internal bump stop on the 5000 pound ultimate bag are a nice bonus.Airlift appears to have what I call a better upper bracket. Probably negligible between ride rites and airlift but it’s closer to how I would build my own.
I have a couple variables from oem so pics of known dimensions would tell me how likely it will be to modify something.
Last night I settled on Airlift kit 88237 and spacer 52440.
Hoping a 4” lift spring needs a 4” spacer.
I really like how they fit together. I might have to keep that in mind for later.This is the airlift 88237 with daystar cups on a 4” lift spring with stock shackle configuration. View attachment 436150
