Without a cv rear shaft your pinion and t/case shaft ned to be at the same angle really. ie: if your t/case shaft was level to the ground, your pinion should be too so that both UJs operate at the same angle. If you're not worried about vibes and are only running at low speed then I don't think you have a problem. There's nothing you can do about the front anyway without cutting off and re-welding your knuckles
Just bear in mind that when you nail it that rear pinion is going to want to point skyward, making that angle even greater.
