Pictures of your truck in the SNOW!
Thanks. It was a fun ride. The shake down run, actually, since I put the one tons on there with the lift and tires. I found a couple small issues I have to deal with, namely relocating the bottom shock mounts on the rear axle and clearancing the front driveshaft. Otherwise, it did fantastic! :D
It's hard to tell from that picture, but I'm going down a very steep hill there with big dips under the front driver's tire and the rear passenger tire. The truck articulates real well. :D
This is my 87 Burb in the snow this morning..........starting tearing it down last night and since there wasn't any adverse weather in the forecast I left everything, including parts and my tools, laying around! :doah:
oops ,
I don't think that was the intention of the original post :whistle:
Well hopefully it will thaw out quick and you can clean it all up and won't rust, is that the spindle or the shaft exposed?
oops ,
that was the spindle and the end of the shaft.......I cleaned it off and sprayed it down with some brake cleaner really well, then covered it with WD40 and wrapped it with some rags until I can get out and finish it up
Well, I guess I could post some of the other SUV in the snow since my Burb was broke(Shocker!!!!)
This has a ton of flex!!
attachment.php
damn global warming...:doah::doah::doah::whistle:
This is more of a pic of my truck out of the snow. I found i can get through more snow if my tires spend less time in it.
Um David. I dont think that first pic counts as "In the snow". Maybe flying over snow!!!!
Sweet!!!!!!
38's and 10 bolt front
I would show you a picture from the front but you would laugh. I have bent a bunch of 10 bolts. I am going to go to 1 tons some time but I like less weight for the snow. Good thing 10 bolts are cheap to free around here. I would really like to save up some money and get a high pinion 60 for the front.
Ah man, totally ruined my 10 bolt high. Lol!
Sent from one a dem der smart phones
