I have a really good way.
Google and buy new.
Google and buy new.
Hav you tried a porta-a-power?I think there's a pretty tight tolerance that U-joints will live through, so you might end up having to replace it. The spacing has to be right, the two ears have to be parallel to each other and the ears have to be the same distance from center, or it will be off balance. Are you confident that just one side is bent?
Maybe a giant bolt through it, with nuts and washers against the inside of each ear. Figure out a way to make good measurements against the shaft center line. Keep tightening the nuts while hitting it with a big torch. Release bolt tension periodically to measure for straightness, etc, comparing to a good one.
This is the way.I have a really good way.
Google and buy new.
You guys are right, buying new is the "correct" way to do it. However, this is a front axle shaft on a light vehicle putting less than 200hp to the wheels. I think it'll survive if I can get it bent back a bit.I have a really good way.
Google and buy new.
Not yet.Hav you tried a porta-a-power?
If you do this, I want blow-by-blow pics.Put a big pie cut in the bend, set it where it needs to be and build it back with the welder![]()
THIS, has happened more than I care to talk about…Hammer it back out during reassembly.
Martin
This ended up being the best way to do it.How long of a pipe do you have handy? You could try clamping the ear and using a cheater pipe (preferably with a close fit to the axleshaft) to apply force to the axle shaft with a long lever.
I have the 10 ton portapower from harbor freight, so I tried it. Didn't do shit. I've had this thing for awhile and I'm surprised at how little it's been useful. Either 10 tons isn't as much pressure as it sounds, or hf is full of shit on the rating.Hav you tried a porta-a-power?
I did try hammering on it a little, but prying on the ear worked best.Hammer it back out during reassembly.
Martin
I think it was an f150.What's the crossmember out of?
I'm trying to keep the width reasonably close to what I have now. The Pathfinder it's based on is between 56-58" width. The Dana35 is already wider at 60", the dana44 would be around 65" wide.The fullsize x member is different than the d35 x member. Why not use d44 beams?
As mentioned above, I readjusted my makeshift crossmember, and I think I'm closer, but it's just too hard to tell if I'm really getting it right or not. I think I'm going to have to do exactly what you said and get my hands on the right crossmember. I think it's the only way to be sure I've got it right.You may have to source a ranger or Explorer crossmember to make it easier. 2wd is different from 4wd on the d35 stuff.
