Pigeon-Rat - Opel gambler build
1966 Opel rekord mounted to 1990 Nissan pathfinder.
Midnight4x4 is a local shop here in Salt Lake. They sell a lot of fab parts, and build custom cages. Great guys to hang with too.
That’s SLC secret 4x4 fab parts place.
I’m always buying little bits and pieces from them.
I bolted a tire back on just to see where things ended up. First, I need to put a bend in the radius arms. I forgot about steering. Doh! Gotta make some room for the tire to swing in.
Second, at full bump (as it is right now), the tire is still a couple inches from the top of the wheel well opening. I've got to be able to do better than that.
I probably need to go with a radius arm style closer to @r3dd0g so that I can aim it at the bottom of the axle, then tie into the top. That way the radius arm isn't limiting my up travel so much.
Also have to rethink some of my crossmember.
Nothing is ever easy.
I made some progress on getting pieces for inside the frame rails. I finally decided it was time to actually learn a bit about using fusion 360. Specifically, I figured out how to import an image as a canvas, then calibrate it to the right size.
First I made a template then took a pic to use for the canvas:
I figured out that having a ruler in the pic made calibration WAY easier.
Once that was done, I just used the line tool to trace it out:
Add in a couple of fillets and 3 point arcs and it looks pretty good!
I've got a friend that has a 4x8 plazma table, so now that I actually can make something he can use, he cut the pieces out for me. His shop is 15 min away from me, and it took all of 5 minutes to cut both pieces.
I can't believe I put off learning this for this long. :doah:
I'll get these bolted up and then continue my crossmember modifications. Looking at it today, I'm fairly certain that I won't even end up using the outside piece on the drivers side. I'm going camping this weekend, so may not be much progress for a few days, but getting these things cut so cleanly feels pretty good.
Got my hands on an 1989 landcruiser steering box. (on the left)
It looks very similar to the Nissan one, but just a touch smaller, so fitment isn't going to be an issue. It accepts the same steering shaft, so that's nice, but the pitman arm doesn't transfer over. Not a big deal, but would have been nice.
I did confirm that it rotates the correct way for the pitman arm to be pointed forward. :waytogo:
I'm going to try and nail down the changes I need to make to the crossmember this week, then I can move on to steering!
I've nailed down the changes to the crossmember. I'm still not as far up as I'd like, but if you look close you can see the alternator is just above the crossmember now. I can't really get any higher without moving it, and there are no high mount kits available.
I'm not willing to design that myself at this point, so this is where it stays.
Send it!
I think I've had another change of heart when it comes to the crossmember and my lack of up travel. As you can see from my previous post, there is only so much room to snake the crossmember in between the alternator and the DS axle... but what if I didn't at all?!?
While watching videos on setting up swingset steering, I realized that the 2wd TTB guys do not run a crossmember between the pivots mounted under each frame rail. That got me thinking.
As you can see in this pic, the DS axle mounts almost directly under the PS frame rail. That means pretty much all of the load is straight into the frame. Unfortunately, because this is a 4x4 axle, the PS axle mounts pretty much in the middle, so I definately need to have that supported by both frame rails, but maybe not the DS axle.
What if I did something like this:
It seems like that might actually be better. It would give both mounts some front to back support, and the front mount should have plenty of vertical support being directly under the axle.
Does that make sense to anyone else? If I lost that section of crossmember it gives me several inches of up travel potentially.
Anyway, I'll noodle on that for a few more days. If anyone has any thoughts, please share.
In the mean time, I picked up a bunch of heim joints and bushings from midnight4x4 so I can get to mocking up the steering. After watching some videos by Dune Hippy, I think I'm going to build it something like this:
I always get worried that I didn’t provide/ or, add enough support structure, when I do stuff like this. But, I always end up “over-building” everything, to the detriment of travel.
When I originally designed my full hydraulic steering, I was deathly afraid of not having enough structure to secure the double ended steering ram.
Then after looking at the Artec truss, I realized I was wrong. 1/4 inch steel is plenty strong.
Anyway, what I wanted to say to you is/was,
“Trust the process” of metal(steel) being strong enough.
I’ll bet the way you described not having that piece of crossmember in there, will more than likely work.
Just my $0.02…
Could you add some tube for support over to the other frame rail if needed? Like with a bend and forward of the diff as long as it didn't interfere with the steering.
I think that is the problem, it would interfere with steering.
One I found that hollander motorsports builds, looks similar to what you're thinking, I think. So long as the drivers mount is supported so it can't deflect backwards I think you will be fine.
Thanks for that pic! That is pretty much what I was thinking! That helps a lot.
I started working on steering... kinda. First step was to mount the new steering box, but part of the reason I hadn't mounted it yet was because I thought I might need to share a bolt or two with the crossmember. Since I've decided that section of the crossmember wasn't necessary, I needed to cut that out first.
Here is the latest version in place.
I haven't added the brace between the front and back section yet, but that will come in the final version.
With that out of the way, steering box went in next.
I got my hands on an fj80 Pittman arm to use for mock up. I think it's likely that I'll have to modify it, but it'll do for now.
In the meantime, since I cut out the part of the crossmember that was causing interference with my up travel, I could help but bolt on the tires and see how much better it is.
Here is the new full bump.
What a VAST improvement! The axle is right up against the bottom of the frame rails. I got 3-4 more inches of bump travel! I'm thrilled with the results.
I need to make sure I can get the steering to work at that much bump, but at least I know my crossmember is no longer my limiting factor.
I'm full on into building the steering now. Having access to my friends plazma table has been a godsend. Of course that means I also have to get better at fusion 360. I'm getting there though.
Here is my sketch of the swingers:
Finding a way to mount the PS swinger in the middle has been rough, but I think I have a plan. I should have something to show tomorrow.
I like that you started your sketch on the origin. Too many beginners just start drawing out in the middle of nowhere. Ideally, you will get all your sketch geometry fully defined. I would also not include the 3/4" holes in your first sketch as a general practice, add those as features after the base geometry so they are easier to edit as individual features. It is less critical on these simple parts, but the more complex you get, the more of a pain it is to put everything in one sketch when you start making adjustments later.
