Pigeon-Rat - Opel gambler build
1966 Opel rekord mounted to 1990 Nissan pathfinder.
I got the radius arms welded up and installed today:
At some point I'm going to box that in, but it's plenty strong enough for now. When I get to doing the suspension, that area might make a good place to mount shocks, etc.
Now that the beams are fully installed I decided to double check clearances.
Sitting on my temporary bump stops everything clears by 1/4" or so! It's hard to tell, but what you're looking at here is the pumkin fully stuffed. The light grey painted piece is the crossmember.
Since my axle u-joint modifications the other day, I've been wanting to test just how much travel that got me. Now that the beams are fully installed, I can check. I measured at the inner C at full stuff, then lowered the beam as much as possible:
Given that my u-joint bottoms out at 37.4*, my math tells me that each axle can drop 18* from flat (18* for each axle for a total difference of 36*).
At this point, I am 19" from full bump. :eek1: That's pretty damn good news considering I was aiming for 14" of travel at the tires.
It's still possible something else will interfere, or the driveshaft won't be able to handle that much droop, etc, but for now I'm ecstatic!
I'll finish putting the axles back together tomorrow, then put the steering together and hopefully set it down on it's tires for the first time in months!
Beam guys call it dirty hooker travel for a reason.
Just ttb swap everything! What are you doing out back to keep up with the new front end?
It'll most likely be coils and a 4 link. Right now it is a 5 link with coils, but the links are pretty short and not a ton of separation on the upper links (hence the track bar link). It'll be tough to get a ton of travel out back unless I'm willing to cut into the cabin. I'm not completely opposed to it, but I want to keep as much interior room as possible, so we'll see.
So are you going to use radius arms or something else?
If you are will you modify one side to get more flex?
I'm not sure I understand the question.
I did get everything put back together yesterday and was able to roll her off the lift for the first time in several months:
No suspension yet, so she's got blocks between the beams and frame to simulate ride height. I'ts not exact, but that's pretty close to how she'll sit going down the road.
I also checked full bump and full droop with the tires and steering all installed. At full bump, the tires tuck into the fenders nicely.
I pulled her up and kept waiting for something it bind, or interfere. I finally stopped at 20" up from full bump. :yikes:
That's 20" up as measured from the middle of the front facia. Nothing binding, no interference. Can't complain about that.
Next on the list (after Blazerbash) will be power steering lines and brake lines.
Oh, and I made a quick little video for the gram:
View attachment VID_20260904_112441_885_bsl.mp4
The original design had limitations on flex because of the design of the radius arms.
Are you using the same design or doing a different suspension system?
Ah, I see. Yes, I build my own radius arms. The biggest issue with the stock ones is that they used poly (or rubber) bushings at the frame side. I'm using heim joints. Also, because I built them myself, I designed them to go lower on the beam end so they can stay below the frame rails on full bump.
What about the attachment point on the axle side? Do you have 2 points top and bottom on both sides or one side?
If it's too much for the pivot bushings it's common to replace the bushings with uniballs, but this style front end is only held in by the pivot bolt at the crossmember and the radius arms. It is nothing like a solid axle in design
The beams travel in an arc, and longer radius arms reduce the amount of caster change in the arc, running swingset steering reduces the amount of toe change in the arc of travel.
Yes and that creates a bind when you have a full flex.
The fix has been to make one side not fixed to relieve the bind.
When I get back from blazerbash and have it back up on the lift I'll have to take a video of the beam cycling. The only possible bind point is the heim joint at the frame side. The axle side can stay rigid because it is free to move through the arc the same as the beam.
Yeah, I assumed I'd need to do that, but so far I haven't seen any issues with binding there at all. My guess is the uniball is more for strength and durability. I could see a lot of hard jumps and extreme cycling of the beams wearing out those bushing fairly quickly. Luckily, the change to uniballs is pretty easy to do, so I'll just keep an eye on it for now.
I had thought about it for when I go to coilovers, but there are lots of daily/desert weekend guys running bushings with good results.
