Are a few pin holds in the rocker panel acceptable at the butt joint? Ideally the pin holds were checked when the welds were ground and before being dressed. Also when dressed should the metal have any deep grinding marks or be smooth?
With filler, the less the better but it's a balance between spending hours and days to get the metal perfect versus putting filler.On the rockers how smooth should the butt weld join be after grinding down the welds? Also for filler on the rocker what thickness would be acceptable over the joint?
how about hammering down the weld joint some to make it flush?With filler, the less the better but it's a balance between spending hours and days to get the metal perfect versus putting filler.
If you can keep the filler down to 1/32" you are golden.
At butt joints it's not the joint area that is the problem but the area needed to blend in the curves to look good.
So you could cover 5" to blend it in if the weld is too high.
Knock it down to no more than 1/32" and you are safe.
That was the extra work I was talking about, if you heat it up and use a hammer and dolly to smash it in you will need less filler, just don't hammer it from one side, you could put in a dent and make it worse.I think for your purposes grinding down to almost flat will be good enough thoughhow about hammering down the weld joint some to make it flush?
