Don Crawford
Just installed a new 8 inch lift on my 84 k5. At about 50 mpH with deceleration I get a quick grind noise from rear end I think it had to do with my pinion angle with new lift. I first had the stock shims that came on new 4 inch rear leafs with the fat part pointed towards the rear this is when I first noticed the sound, and the drive shaft was almost straight on with rear diff. So I loosened u bolts and tapped the shims to fat towards the front and sound was a little better but still there. Any help would be much appreciated. Thank you.
