3MAX
I just finished my build and got my Blazer back on the road, but it seems I've got an issue to sort out.
I get a grinding / whining noise when I let off the throttle going over 30mph. It only lasts a couple of seconds, and it only does it after being on the throttle. I can cause the noise at will by feathering on and off the throttle over 30mph.
I'm certain it's coming from the rear end, and according to internet diagnosis, this is pinion bearing noise caused by lack of preload.
The axle is a 14 bolt semi-float that I rebuilt. I'm 100% certain that I set the preload correctly during assembly. I even purchased an inch-lb torque wrench specifically for this purpose.
Tonight I set the rear end on jack stands and dropped the drive shaft to check the pinion for any play. Nothing. Nada. even checked it with a dial indicator - I couldn't get any end play or side to side movement, even when hitting it with a dead blow hammer.
So... what now? Could there be another issue causing the noise? I just hate to go through the rear end again before checking all possibilities.
