3MAX
I went through the exact same thinking you are going through right now. And I had the exact same noises you are having in the exact same situations, to where I couldn't think that it was the driveshaft/slip yoke being pulled out to far. But when I changed my setup....like I said....smooooth. The last thing I like doing is throwing money at parts that are not necessary
I certainly can't argue with that.
I'm going to go ahead and try the output shaft bearing since it's relatively cheap and easy, and since the T-case is the ONLY item on this Blazer that hasn't been rebuilt. If that doesn't solve it, I'll go for a CV shaft next.
I do appreciate your advice
I had convinced myself that it had to be the pinion bearings due to the sound and the conditions when it made noise, plus the fact that it's gradually getting worse... Oh well, live and learn. Time to look into a CV driveshaft I suppose.
