I am doing the numbers to get a working pinion depth and the numbers on the end of the old and new pinion are nebulous.
OLD pinion is on the right and I am guessing the number is +2.45 (Is that correct?)
NEW pinion is on the left and I am pretty sure the number is 0.0 (Is that correct?)
I have no idea what the others numbers are however, the AN022 on the new pinion is also inscribed on the ring gear.
I don't know what the 3,129 inscribed in the old pinion is...
Math says to subtract the NEW pinion from the old
2.45 - 0.0 = 2.45
I will be ADDING .00245 to the inner shim stack on top of the old shim stack total.
Thoughts?
2.45 - 0.0 = 2.45
Thoughts?
