WinslowS
Anyone know a torque spec for a front pinion nut? I need to replace the pinion seal.
Actually just found this in the GM manual. Mark the threads/pinion nut/yoke before removal, check force needed to rotate the pinion, (in in-lbs) record that info, disassemble, reassemble, measure force again, making it 3 in-lbs harder to rotate than before.
As others have said, once you mark the relationship, you put it back together so everything is lined up, then check bearing preload, in small increments getting 3 in-lbs above what it was before you disassembled.Well I might have messed up, this is the second seal since october. The first time I changed it I tried the count the treads and mark it, but I somehow erased my mark on the nut. So I just threw it all back together. Took it up to Uwharrie, and one mudding trip. I haven't heard any funny noises or anything, butthe seal is leaking again. I wanna fix this the right way, but would prefer not having to replace all the bearings. I've been searching, and am not sure exactly how I should fix this.
Yeah but I never checked pinion preload. I just sorta tightened it back up. And now I have no reference.
I've actually done that 4 times, (pull the pinion nut and not marked or measured anything) and only once had a problem. The torque on the *new* crush sleeve is huge, I just used a large breaker bar to tighten them back down. This was all before I knew better, of course.
If the gears aren't growling at you, you may be ok. Only time it didn't work for me, the gears made noise.
