I've done the search, read all I can find and decided to try the "mark the nut position" method. They raise the rear and apply the E-brake and proceed.
My question, Is it necessary to raise the the rear off the ground?
My E-brake is disconnected, so I'm unable to lock the diff to remove the nut. Can I follow the same procedure on the ground?
79 GMC K1500
79 GMC K1500
