pinion shim question ?
BL1TZKRIEG
OREGON
hi my pinion needs to be lowered 4 degrees to
match my transfer case u joint angle
my question is should I get a 4 degree shim?
or should I get a 6 degree shim to compensate for the pinion raising up when I hit the gas
General rule of thumb is the pinion will rotate 1-2 degrees up under throttle. Of course that varies greatly based upon leaf spring rate and whether blocks are involved.
BL1TZKRIEG said:
I have 5 1/2 inch tall blocks so it defiantly has some leverage there
If you are going to use blocks to get your lift they really shouldn't be over 4 inches anything more then that and your just asking for problems..
