454Sub
5/8 ton status
I have a Burb, I have 4in lift springs in the rear and ran 4in blocks. Well, after I installed the ORD flip kit, my pinion is basically pointing into the rear seats. At the time, all I had was the shims from the blocks, so I beat them around with a hammer to bring the pinion back down some. Have any of you ran across a shim that can bring it down farther? Or is it more of a cutting perches off and reweld type fix?
